Group: DynoMotion Message: 6181 From: chrismd500 Date: 11/29/2012
Subject: Kstep limit switches connection..
Hi
A couple quick questions to make sure I'm correct: Let say I want to have a limit switch to bit 180 on the Kflop. I would then connect (via a wire) one of the limit switch connectors to JP33 pin 21 (opto IN 12) on the Kstep. I would also connect a wire from the power supply 24V+ to pin 8 on the kstep and the power supply 24V- to the other limit switch connector? Anything else I need to do?
Is it the same for both a NO and a NC connection?
Thank you! Sorry for all my newbie questions.
Group: DynoMotion Message: 6182 From: Tom Kerekes Date: 11/29/2012
Subject: Re: Kstep limit switches connection..
That is all correct.
Group: DynoMotion Message: 6183 From: chrismd500 Date: 11/29/2012
Thanks!
> From: chrismd500 <kristoffer.jensen@...>
> Sent: Thursday, November 29, 2012 8:58 AM
> Subject: [DynoMotion] Kstep limit switches connection..
> Hi
